jrnymn7
Jun 24, 2015Explorer
3"x3"x2" sealed junction box, water resistant box connectors, a few 5/16" nuts and bolts, a little silicone, and yer good to go... put the $220+ you save into heavier cabling and whatever else the remaining $200 will buy you.
Will work with both series and parallel wiring, using 3 studs:
in series, (using all 3 studs), one panel's pos and the other panel's neg to a common stud. the remaining panels' pos and neg each to a stud that also have pos and neg to controller.
in parallel, (using 2 of the studs) both panels' pos to pos stud to controller, and both panels' neg to neg stud to controller.
