mchero
Jun 25, 2015Explorer
opnspaces wrote:
As others have stated Micro inverters will not work. Micro inverters have to be hooked to the utility grid. When the grid goes down the the inverters shut down to protect the linemen working on restoring power.
In fact I was just talking to the local building inspector last week for solar that I'm installing on my house. In San Diego you have to put warning stickers on the conduit coming down from the panels that warns that they are carrying solar power. I assume this is to protect the electrician that flips the main breaker and assumes that all lines are dead in the house when in fact the solar is back feeding power through the breaker panel. The inspector said I do not need the warning stickers if using micro inverters because when the main cuts the power the inverters all shut off too.
Opnspaces
Read the thread from the beginning. You will see that I was QUICKLY corrected! LOL
Thanks for the information.
