mchero
Jun 25, 2015Explorer
jrnymn7 wrote:
3"x3"x2" sealed junction box, water resistant box connectors, a few 5/16" nuts and bolts, a little silicone, and yer good to go... put the $220+ you save into heavier cabling and whatever else the remaining $200 will buy you.
Will work with both series and parallel wiring, using 3 studs:
in series, (using all 3 studs), one panel's pos and the other panel's neg to a common stud. the remaining panels' pos and neg each to a stud that also have pos and neg to controller.
in parallel, (using 2 of the studs) both panels' pos to pos stud to controller, and both panels' neg to neg stud to controller.
Still in the design stage jrnymn7, thus the reason for the questions.
Might be going series and elimate the $200+ combiner box. Good ideas, thanks.
