MEXICOWANDERER
Aug 03, 2015Explorer
Whomever you asked undoubtedly has not been closer than 4 airline hours from the Mexican border.
Your local propane gas delivery service sells inline filters. Forget what they might "say". Ask them if they want to buy two thousand dollars worth of equipment plugged with oil. Some, 14 pounds, empty, pots weigh 22 lbs with the valve wide open. I don't think they're filled with Chanel No. 5
AMAZON AD
by Nashfuel
Nashfuel Universal Inline Propane Filter High Capacity
1 customer review
Price: $40.99 & FREE Shipping
GOES BETWEEN THE TANK AND PRESSURE REGULATOR. High Pressure only. Take old heavy tank to Mexican LPG shop and have them remove the valve for you. Put 2 gallons of MAGNA into the tank. Shake to dilute accumulated oil. Then dump. BE CAREFUL or you'll smell like a bad propane leak for two weeks. Let the tank air dry for three days. Then re-install the valve. Should last 5 years or so until oil and crud load up again. This filter will save the valve on your heater ten times over. Mexican LPG can be horribly dirty.
AMAZON AD
by Nashfuel
1 customer review
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
