StirCrazy
Nov 09, 2022Moderator
Cptnvideo wrote:
StirCrazy, first you have a 50 amp RV. Then, plugged into 15,20 or 30 amp shore power. Then your load would be a little more than shore power provides, therefore necessitating load sharing.
Since GoPower (in all their wisdom) does not monitor or take into account the current draw on Line 2, you must know the current draw on Line 2 and take that into account when setting the incoming current limit.
I have the capability to provide additional power from my solar and battery system, so why not use it. In other words, I can run 2 A/C units while on 15 amp service, but I need to know current draw on both legs and limit accordingly.
ya I got a 50 amp but the way I camp I have probabaly never used it as I am either plugged into 50 amp (only have 1 ac) or Im running of the batteries and solar so I have never been in the situation to use the load sharing part.
so I guess for me, I would only have to know the current of the leg the ac is on to do that since I only have 1? and if that so I could do that if I ever desired I guess...
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
