- StirCrazyModerator
StirCrazy wrote:
Cptnvideo wrote:
StirCrazy, I apologize if I insulted you. However that is exactly what you did when you basically said I didn't know the product I owned. You implied that I was stupid.
sorry if it came accross that way, I should have asked where did you find this out as I wanted to look at it also. I was under the asumption it did monitor both legs.
so my next question, how does this affect us and why are we concerned about it, I have been blisfully ignorant of it for years, should I even be worried about it now? - StirCrazyModerator
sorry if it came accross that way, I should have asked where did you find this out as I wanted to look at it also. I was under the asumption it did monitor both legs. - Tom_BarbExplorer
Cptnvideo wrote:
Will it display amps for both Line 1 and Line 2?
ours will... on a display to my phone. it requires a dongal device - From a post by TechWriter, it appears the Victron shows the combined current draw of the 2 lines. I don't know how their load sharing works which they call "load assist".
I should have done more research instead of relying on the installer's advice. But I assumed they knew best. - 3_tonsExplorer IIIWell, it would be interesting to see how the GoPower differs from the Victron?
3 tons - pianotunaNomad III
Cptnvideo wrote:
Since I have solar, it really doesn't affect it all that much. Another call to GoPower (and different tech) produced the opposite response. But I tested both ways, charger on and off, and tests confirmed charger must be on. (Maybe I have a defective inverter.)
Fortunately, charge rate can be adjusted to 1% on the inverter/charger but one should not have to do that.
It doesn't behave like the Magnum Load Support.
I don't think you have a defective inverter/charger.
From those that have Victrons--I've heard they operate in a similar fashion to the Magnum.
For both the Magnum and Victron, the inverter must be on to do load support.
The magnum chose to use 120 volt cooling fans. So if the unit has been heavily loaded and it is shut off, it can catch on fire. DAMHIK. (They did replace it under warranty)
Neither of them do voltage support--which is why I have a stand alone autoformer. - Pianotuna, maybe that is the case. Charger is turned on but not actually trying to charge.
- Since I have solar, it really doesn't affect it all that much. Another call to GoPower (and different tech) produced the opposite response. But I tested both ways, charger on and off, and tests confirmed charger must be on. (Maybe I have a defective inverter.)
Fortunately, charge rate can be adjusted to 1% on the inverter/charger but one should not have to do that. - pianotunaNomad IIICptnvideo,
An inverter charger, to do load sharing, must have some kind of autoformer. That means it will *not* charge when it is in "share" mode.
I've got the monitor where I can see it. It NEVER charges until the load share stops, or is turned off.
If the GoPower charges and load shares at the same time that is weird.
It would mean that the GoPower is simply doing double conversion. I.E. drawing all power from the battery bank while only using the shore power to charge the battery bank.
I used to do that lots when I didn't have an inverter/charger. I'd only plug in the converter. - 3_tonsExplorer III
Cptnvideo wrote:
By design. I spoke to GoPower about an hour ago to confirm. Current on Line 2 is not displayed. Nor is it limited during load sharing.
Another tidbit. Since we have 1600 watts of solar, we don't have the charger portion of the inverter turned on. But load sharing does NOT work unless the charger is turned on. That is also a design flaw - so the charger is on trying to charge the batteries while current is drawn from the batteries to share the load.
That’s very curious - But some good sleuth work though :) , particularly the possibility that load sharing requires the charger on line…In this regard my ‘uninformed question’ would be, isn’t load sharing a feature thats designed to assist deficiencies with shore power, and if so, how does having the charger on (say, concurrent with shore power) adversely impact the solar charging option?? Thanks :) (dummy me - lol).
3 tons
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
