Cptnvideo's avatar
Nov 04, 2022
Anyone familiar with or have a Victron MultiPlus-II inverter
We are looking into replacing our GoPower IC3000 inverter with the Victron model on the subject line.
Reason: the GoPower only monitors and controls load sharing on Line 1.
It is my understanding that the Victron does this on both lines of 50 amp service but calls it "assist". Does it come with or is a control/monitor panel (for settings, etc) available for the RV interior?
  • 3_tons's avatar
    3_tons
    Explorer III
    Cptnvideo wrote:
    TechWriter, nice setup you have there.
    Don, that is a thought. I'm planning on adding one more 206 ah LFP battery, so I could go 24 series/parallel or 48 all in series.
    From my perspective (admittedly a subjective topic), I see little gain in many cases for switching to a higher voltage - some considerations are as follows (JMO only):
    Where the inverter can be located reasonably close to a sufficiently sized battery bank, and with proper cable sizing for anticipated loads - this helps avoids voltage and current bottlenecks…
    Higher voltage configurations make sense where certain high current or ‘reactive’ appliances and motors are at a considerable distance from the battery bank (ideal on a yacht!). The higher voltage advantage here being that lighter gauge long wiring runs can be used.
    Though somewhat slight, over time some efficiency is spent when stepping back down to 12v.
    With LiFePo4 batteries, dreaded voltage sag is mostly inconsequential (throughout usable depth of discharge), often making their application ideal for both 12v and inverter supplied 120v loads - in this way LiFePo4 batteries may negate the advantage of a higher battery bank voltage…
    Admittedly (having a truck camper…) this is just my own rational while still open minded, but would be most interested in hearing experiences from others!
    3 tons
  • TechWriter, nice setup you have there.
    Yes. Inside my RV I have a Victron Touch 50 display which animates your power situation:
    Touch 50 display at work
    Also, the Touch 50 can be accessed via BlueTooth (good for 10-20 feet) and over the Internet if your Touch 50 is setup to a WiFI hotspot like so (on an iPhone):
    From the Touch 50 display you can access a multitude a parameters . . .
    It slices, it dices. My Victron RV install
  • Cptnvideo,
    if you are going to replace the inverter, seriously consider a 24 or 48 voltage configuration for the battery bank.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
