schlep1967
Oct 27, 2015Nomad
The next thing you will find out is if you set it at 70 degrees the furnace will shut off when it reaches that temperature. But it will only be 70 degrees up at the ceiling where the thermostat is. Set it a few degrees warmer than you want it so you get the proper temp down at living level.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
