MEXICOWANDERER
Aug 05, 2017Explorer
- Mexico is the land of the vertical learning curve when it comes to water filtration and treatment
- A mesh-type primary filter stops a lot of junk in it's tracks
- I use a ROTOPLAST one micron disposable spin on. It absolutely stops giardia and amoebas
- Virus is killed with UV
- But the water needs to be thoroughly irradiated
- Time versus intensity
- Look it up on GOOGLE and Wikipedia
- R/O systems are a joke unless pressure is boosted to at least 100 psi and a real membrane filter is used
- The two most important points are only a good R/O system will remove excess minerals. Only a good R/O system will substantially reduce levels of heavy metals - the type that produce three-eyed grandchildren.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
