Traveler7
Aug 06, 2017Explorer
TechWriter wrote:Traveler7 wrote:TechWriter wrote:Traveler7 wrote:
Here is one I am considering-
SafH2OUV Model 212
It's a 2 gpm unit. That's pretty slow flow.
I only have a 15 Gal Tank and I think the slow flow promotes a good exposure to the UV for purification so to me that is a feature and not a bug.
I don't think you understand . . . my concern over 2 gpm is not the UV output -- it's the input.
If you connect it to a water source that's > 2 gpm (a distinct possibility), then your UV sterilizer won't work.
I do not have a city water connection and will be using a Shurflo 3gpm pump, but I don't think it will make a difference. I believe the 2 gpm figure is how fast the water will flow thru the prefilter and unit. Usually that number is an outflow number and unrelated to the inflow. This unit is designed for an RV so it must be more flexible than that.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
