sdetweil
Mar 26, 2015Explorer
Stefonius wrote:sdetweil wrote:It's your second link. The kits would be on page number 37 & 38 (41st and 42nd page in the document). Not sure what they cost, but I think the best option would be the underfloor mount. The material at the top of the compartment is quite a bit sturdier than the sheet metal floor.Stefonius wrote:thanks.. I think that catalog is here page 16 shows a slide out, but it is under floor again. pages 28 & 29 show more of the same.
Sdetweil - I have a PDF copy of the Onan Generator Accessory Catalog. They make two different mounting options for our gensets in a FW front compartment. The underfloor mounting kit attaches to the sides of the generator, and then bolts to the TOP of the FW's front compartment. The genset basically hangs in place. The other option is a slide out tray that goes into the floor of the compartment. In either case, you'll be cutting out a large rectangular section of the compartment floor. The generator gets combustion air, cooling air and exhausts from the bottom. I am having trouble finding an active link for this catalog, so I can't post a link, but I'll PM it to you if you'd like to see it.
or here pages 53 & 54.. that slide set on page 53 is $832!
ok, got it.. my enclosure is based on floor mount.. looks like this
(this is not mine, but mine is similar)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
