Horizon170
Apr 29, 2014Explorer
As I understand it, you have three doors to keep closed. Two side by side and one on the bottom that opens from the top.
If this is true then my solution would be to install a"T" brace.
Clicky
You would secure it at the proper point where the three doors are at a junction point by tapping into the fridg case. Gravity would hole the "T" in place. To open the bottom door you rotate the "T" 180 degrees. To open the right door you rotate the "T" 90 degrees clockwise and to open the left door you rotate the "T" 90 degrees counterclockwise.
Felt glued to the back would prevent scratching of the paint and you could use you imagination of items on hand to decorate the front of the "T".
t
Clicky
t
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
