past-MIdirector
Dec 15, 2013Explorer
Check the master cyl. there was a period where they had a lot of problems with master cyl. leaking. Easiest way to check is if you have level system raise the front a few inches and turn the steering wheel all the way to the right. This will give you enough room to get in and check the brake fluid also a small mirror helps. There was also a problem with the rubber fluid lines to the front Calipers that would deteriorate internally and block the fluid. Lastly you want to completely change all brake fluid and should be done at least every 5 years!
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
