JiminDenver
Feb 05, 2013Explorer II
I figured this would become a Honda/Yamaha vs Champion thread. Sigh
Are the Champs perfect, no. Search the forum for problems with the big names and you will find they are not perfect either.
Still for the money saved, the vast majority of people that use the Champs are happy with them even if they are inferior to the big names. Mine may not be as good, but it fills my needs and that is good enough not to have to spend the big bucks on the big names.
BTW I am the third owner of my older 3500/4000. The original owner used it to run his trailer. He sold the both to the second owner that used it to run that and after he sold the trailer, he used it to run his cabin. By it's appearance and the oil that came out when I changed it, I can tell you it was not pampered. Still it starts with one or two pulls every time if it's below freezing or 100 outside. It'll run our AC at 5280 ft and even 9200 ft as long as the converter isn't pulling power to charge the battery. A good buy for $62 used. I'd buy another tomorrow if it died, that is unless the new Champion 3100 inverter model proves to be as dependable. Then I might spend the $899 for it.
Actually come to think of it, my solar will do the charging and any inverter model will have to ramp up to run the AC, especially up there, so I may not be gaining much for the money spent considering the need for AC at that altitude is rare.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
