Sam_Spade
Jul 14, 2017Explorer
I hope you realize that you also need a vacuum pump (a fairly healthy one) to evacuate the system before you pump a full charge of freon back into it.
Then.....leaks are most often located by putting a little freon in and using an electronic "sniffer" to find the leak.
What if the leak turns out to be in the compressor ? Or in the evaporator or condensor ??
Layman attempts to fix "non-servicable" refrigeration units usually turn out bad......with the best ones just wasting time and money.....and the worst ones ending up with injuries.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
