ken56
Jul 15, 2017Explorer
The only place you are going to get 410A is with a heating and cooling business. Ports will have to be soldered in and the system evacuated and moisture boiled out and Then refilled with proper refrigerant. DO NOT use 134 to find the leak. That will contaminate the system and another procedure will have to be done to clean it out. Its quite involved and if you do it then take it off the roof and into a shop to do all the work.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
