down_home
Oct 09, 2013Explorer II
all most of us have are the black foam filters on the heat pumps and none on the propane furnaces. I have seen the foam filter loaded us from dust and apparently cooking oil vapors. Since we had a large hole sealed under the shower sealed and several leaks around the coach, from manufacture and where the Dealer wrecked it we see a lot less dirt. We still vacuum and clean when we first put down the jacks though.
It would seem that there is room for improvement and someone should make filters for the furnace returns and the air conditioners andheat pumps. reluctant to cut high filtration rate material and somehow place in them because of frequent warnings of severe problems with the propane furnaces and air conditioners.
Anyone installed better ac filtration that is easy to replace with good results and furnace filters in the heat returns?
