Skibane
Nov 01, 2021Explorer II
ktmrfs wrote:
And if your lucky enough that the low setting of 1500BTU is enough, great, but if you need 5000BTU or more, compounds the potential moisture issue.
1,500 continuous BTUs is roughly equivalent to a 15,000 BTU furnace running 10 percent of the time.
Max output of this particular heater is 3,000 BTUs. If I need more than that, the furnace can make up the difference.
Using the furnace a little beats using it a lot, IMO.
Then again, if you're really that concerned about the extra moisture, just leave one of the kids at home. :B
