PerryB67
Nov 05, 2021Explorer
Skibane wrote:I suppose I could get a micrometer out to measure the distance, but I'm lazy and just eyeball the gap and just want to see the outside, with my eyesight somewhere around a 1/4" is what I shoot for.
In residential heating, a typical recommendation is 1 square inch of opening for every 4,000 BTUs of heater.
Using that guideline, a 3,000 BTU catalytic heater would need at least 0.75 square inches.
So, if your window is 12 inches high, you would only need to crack it open by about 1/16th of an inch to get that 0.75 square inches.
Add in another 100% safety margin, and you're still at only 1/8th of an inch.
Our awning window is about 18" x 14". Considering its an awning you can only use the 14" once, so about 32" in length times 1/4" is 8 square inches. When I was researching catalytic heaters I remember 4-6 square inches per 1000 btu's. At 1,500 btu's I need 6-9 square inches. Remember we're talking about an indoor catalytic heater, not residential heating.
The Weber runs for about 8-10 hours on .8# of propane. I waste too much gas trying to fill those Flame King cylinders to one pound and .8 pounds works for us.
Enjoy,
Perry
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
