Old-Biscuit
Oct 22, 2016Explorer III
No problem
If you look at end of trailer umbilical cord plug with raised part UP
11 o'clock is 12V HOT
7 o'clock is brake controller output
Make up a momentary spring loaded toggle switch with flat terminals and push them into corresponding pin positions
Then toggle on/off for braking as needed.
When On you will have FULL trailer battery voltage so limit amount of on time.
Otherwise brake magnets could be damaged
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
