Gjac's avatar
Gjac
Explorer III
Nov 04, 2016
Are all amp hrs equal?
Say you have 230 amp hrs in 2 6vGC batteries and you discharge at a low amp rate say 1 amp so if you discharge to 50 percent SOC you should have used 115 amps in 115 hrs. If you then discharge at a higher rate say 10 amps would it then take 11.5 hrs to get to 50 percent SOC? Or does the higher discharge rate create more heat and loss occurs during discharge causing batteries to have less amp hrs?
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
