mena661
Sep 28, 2013Explorer
Matt_Colie wrote:Batteries play just fine in parallel. With the OP's problem it would be good to charge them separately to isolate his problem. Under normal circumstances, there is absolutely no reason not to charge batteries in parallel together. I don't know where this misleading information comes from but it is utterly false. The SG readings of my series/parallel battery bank are spot on with each battery. I charge them ALL at the same time everytime.
Lead/Acid batteries do not play well in parallel.
As DonDat said, you have to charge them separately. What he neglected to say was that to get full power out of them, you always have to charge them separately.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
