MEXICOWANDERER
Sep 28, 2013Explorer
The construction of golf car AGM batteries is exactly the same as for their version of cyclable AGM batteries. Divide price by ampere hours. Pick the battery size that jams in best.
The AGM batteries can charge much faster. If I had 200 ampere hours of AGM located fifteen feet away from the alternator I would use no smaller than FOUR GAUGE WIRE, directly from the alternator output stud, through a battery separator then to a breaker and run directly to the battery bank. This is for usage where alternator charging was the primary means of recharging other than by generator and "converter".
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
