fitznj's avatar
fitznj
Are self-adjusting brakes really self-adjusting?
Looking to upgrade(?) from regular manual trailer brakes to the self-adjusting type (Nev-R-Adjust) - I'm tired of crawling under the camper and struggling with the manual adjusters. Brakes work great when adjusted correctly but.......
Like to hear from people who have long-term experience with the self-adjusting brakes.
Do they still work 1 year, 2 years...... after install or do they jam after they get dirty?
(PS - not interested in changing over to discs)
thanks - Gerry
  • You do not have to back up for the brakes to adjust. Yes, automotive brakes require this but Dexter never adjust brakes adjust while braking going forward.
  • They work fine, but you have to back up quite a bit. Going backwards 10 feet once a month isn't going to do it. When cars had self adjusting drum brakes, look how often you backed up and applied the brakes so they'd adjust.
  • By the time I did the swap I would have disk brakes installed.
    BTW for donn0128, Nev-R-Adjust is forward adjusting.
  • Yes they self adjust, yours worked great until the day I removed them to install disk brakes. It was cheaper to install disks than replace my Dexter HD brake drums and backing plates,they were wore out after 12 years of heavy use.
    Denny
  • When is the last time you heard of issues with self adjusters in the auto industry? Of course they will never adjust if you never back your trailer up.
