MEXICOWANDERER's avatar
Oct 16, 2014
Are The Old WFCO CONVERTER FANS VARIABLE SPEED?
Yes I am lazy. I don't want to carry the WFCO module to my battery and play with it on the floor.
The WFCO has a fan driver transistor whose part number is so small and faint I cannot read it even with 8 diopter and 800 lumens of lighting.
If the fan driver circuit is single speed, it's going to be detoured to a relay coil and the relay is going to have 30 amps capacity.
WFCO decided to use a sleeve bearing fan. Cheap. But positioning the fan to blow PARALLEL to the main heatsink fins is a no-no. Rather dumb. I am fitting a small metal shield between the pair of vertical ceramic wire-wound resistors and the nearby electrolytic capacitors. A small fan will be directed at the resistors carrying heat away from components. The heat sink gets a pair of smaller ball bearing fans, with a greater CFM capacity. They will direct airflow perpendicular into the heat sink. The original fan is going to be replaced with a quieter ball bearing fan with 10% greater air flow.
But modifications have to start with the basics. The driver transistor and whether it is thermistor controlled. If yes, the transistor's operating current limit...
Also I blew with with me losing the MODIFICATIONS IMAGE of the unit's charging circuit. The image of the MANUAL OVER-RIDE which triggers the unit into 4 hour 14.4 boost mode. After losing a three hour site search exercise I have to yell for help from one of the forum WFCO pro's. Can you PM the mods and images to me or send them to
mexbungalows@gmail.com
Mil Gracias!
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
