BeerBrewer's avatar
BeerBrewer
Are TPMS questions
I've been considering getting TPMS system and I can't decide upon what type of sensors to go with (caps, flow through or internal. Is one better than another?
Does the weight of the sensor (cap or flow thru) effect the valve stem? Does the weight of them causing the stem to wear out and leak air?
How often are TPMS sensors stolen?
Are the sensors interchangeable between manufactures? Meaning will a STS sensor work on a Bellacore TPMS for example?
I've also heard that some systems will display the last know good value if the sensors loses connection to the display unit. This seems like a really really dumb feature. The only possible reason for that feature would be to mask communication issues between the sensors and the system. Are there TPMS that don't do this? If so, please do tell! I'd personally rather see something like "sensor lost" than the last know value.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Jun 17, 2022
