wolfe10
Jul 02, 2019Explorer
I reached out to the designer/builder of the ARP Frig Defend.
Here is his reply:
Thanks for the feedback, and letting us know that you have an Amish cooling unit.
First and foremost, IR temperature readings are challenging to get an accurate reading.
Next, 329F = 165C, this is actually a low boiler temperature, but the boiler could be warming up or cooling down?
The normal range for a Norcold 1200 is 185 to 195C (365 - 383F).
Please note that the "normal" temperature for any cooling unit is dependent upon the pressure that the cooling unit was charged with. Also note, 482F (250C) is not the point at which the ARP shuts off at. Also, please see letter from Norcold to ARP at this link:
https://www.arprv.com/arp-versus-norcold-recall.php which states that the recall will only respond after 800F (427C), which is also the yield point of the cooling unit tubing with the normal charge pressure.
Here is his reply:
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
