MDKMDK
Mar 07, 2018Explorer
Could you flatten your walls with a circular disk pad bit in the drill, and some very coarse adhesive sanding circular disks?
I'm not sure I'm getting the correct mental image of the "cells" inside the larger box, if that's what they are. Sort of grind them flat with a circular disk sanding setup?
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
