NinerBikes
Aug 23, 2015Explorer
Naio wrote:
Thanks, guys! My biggest charger is a 30 amp Noco. Others are 5 amp smart and fairly-dumb...including one smartie that I suspect of being a mislabeled 2amp-er.
The fairly-dumb is an automotive transformer-type I bought new about 15 years ago. It has automatic shutoff, and it does taper.
I can check outputs as I get a chance, have commitments during the day today. Do you really want photos, or just make and model?
I'd go with the UL labels, that it doesn't draw more than 5 amps at 120 or 110V input, and definitely what the output voltage measures at, not what is claimed. 14.8V or a bit more is what it needs to be capable of.
Adjustable Output Voltage is the supreme feature of a Borg or a Borgette, or a Meanwell/MegaWatt PSU. With adjustable Output Voltage, you will get 14.8V, or more if cold, or less if hot, exactly what your battery needs, based on temperature.
You can diddle for efficiency to your little heart's desire with a Borg or a Meanwell/Megawatt.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
