NinerBikes
Aug 25, 2015Explorer
SCVJeff wrote:
I wouldn't worry about bumps on a 10T pot. If I saw one it would go into the trash simply cuz thats a problem looking for a place to start. Theres no reason to find a pot that just squeaks by, especially if you are tracking its output with a DVM. I have SOME 10T pots left, but dunno their size. Will a 2K sweep the range?
1k 10 turn pot more than sweeps the range,
If the 500 ohm pot I have gets me down to 13.4V, minimum then I am good. A 13.2v to 15.5 range is plenty. It's mainly to be used as a bulk charger, for quick and dirty bulk charging of a 158AH AGM Teleco battery I recently picked up, so 30 amps is well on the low side for this battery amperage wise, to not hurt or heat up anything.
Running the MegaWatt off a generator, first thing in the morning, to replenish the battery in bulk mode, on cloudy days. The solar panel will handle all the sunny days in bulk and top charge.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
