EdTheEdge's avatar
EdTheEdge
Assistance on new house battery
First off I know very little about this subject but want to learn, so please bear with me....
I have a Harris 27D170 battery as a house battery in my MH that is connected to a 30amp Sunforce solar controller. I would like to find out if I can upgrade the battery to one that will last longer during boondocking. The battery is now 5 years old and will probably need to be changed soon anyway. I am not even sure if this battery is a deep cycle or not.
I am also not sure how much of an upgrade I can pursue with my solar panels/controller. The specs on the battery from the Harris website are below. Any help on this would be greatly appreciated. TIA.
PRODUCT SPECIFICATIONS:
Harris Battery Part #: 27D170
Volts: 12
BCI Group Size: 27DC
Weight lbs: 50.10
Weight kg: 22.72
Length inches: 12 5/8
Length mm: 320.00
Width inches: 6 5/8
Width mm: 168.00
Height inches: 9 1/4
Height mm: 235.00
Cranking Amps @ 32°F 0°C: 750
Cold Cranking Amps @ 0°F
-18°C:
600
Reserve Capacity @ 25 Amps: 160
Core Unit: 1.00
  • Any battery mentioning “cold cranking amps” isn’t a great house battery. Do you have room for two six volt batteries? Have you calculated your average amp hour use per day? Start there. Lots of online tutorials.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
