time2roll
Sep 19, 2015Nomad
Turn off the main breakers in the RV. You should then have no continuity between the plug L1-L2 also no continuity between L1-N or L2-N.
Post the results. Next will be disconnecting wire to isolate the short.
Do not continue to plug into 50 amps to verify if the short has been isolated.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
