duggram
Sep 20, 2015Explorer
Bobbo wrote:duggram wrote:
Thanks for the quick replies. I was hooked up to a 15 amp 110 volt outlet
This changes everything. If you have much stuff powered on, you will trip the 15 amp breaker at the house. The converter alone can pull half of that or more if the batteries are very low.
If you re-read my first response above, I stated that you had problems if you were popping a 50 amp breaker at the house. I didn't know it was only a 15 amp breaker.
Turn off EVERYTHING in the RV and try again.
Thank you for your comment, however I've been using that 110 outlet at home with my trailer for more than 6 years now and I've never had a circuit breaker issue on that circuit. I understand how to safely use it.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
