D_E_Bishop
Sep 20, 2015Explorer
In your last post you stated that with the CB labeled GCA off and all others on the ATS hummed and yet you had no 120vac. I find that suspect. Do you have a DMM or a 120vac test light? If so have you tested the load side of the CB's? How many do you have?
The GFCI would be on the load side of one of the breakers and shouldn't cut all power in your trailer. I would guess that the ATS is working if turning on the breaker labeled GCA trips the house breaker. If you have unplugged or turned off all 120vac powered items and you are still tripping the house breaker, you have a dead short on the load side of that breaker.
This is why it is so important to label all your breakers, and to designate which breaker feeds the GFCI(s).
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
