jmckelvy
Jan 03, 2016Explorer
Fuses and circuit breakers are intended to protect the wiring in a system.
Depending on which wire table, the application, and type of copper wire the recommended max current for a 1/0 copper wire is anywhere from 150 to 250 amps. You won't need anything close to that for a fuse in your application and no need for wire that size.
Go with slightly smaller wire as it's easier to work with.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
