Earl_E
Jun 16, 2015Explorer
Also, find some clean, dry wood slats or boards. Once the glue is dry lay the strips across the plywood 6" to 12" apart. That way you can lay the fiberglass on top the strips get it perfect,then pull the strips out one at a time as you stick the fiberglass down.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
