Flyin_Finn
Jun 16, 2015Explorer
Joe417 wrote:
I tried to do it using the method you mentioned and was unable to make it work. I tried several different adhesive without positive results.
Putting the glass on the wood first made the panel too stiff, it wouldn't conform to the curve of the front. Stiffness being the whole idea in "plywood", that extra 1/16" of glass made the 1/8" plywood too rigid for my use.
I then tried putting curf cuts about 1/8" apart which didn't work either.
I had to put the 1/8" plywood on the camper and then put the glass on the plywood.
That being said, I was using polyurethane adhesive which could have been the problem. I didn't try contact cement which may have some give to allow it to bend. Polyurethane works well for bonding fiberglass to other surfaces because it doesn't need air to cure.
Once finished, everything turn out great. Hope yours does too.
Keep us updated with the result.
The area I am working on is flat, no curves, and I am gluing this together on the garage floor, so I don't believe there will be any bending issues.
For a moment I thought about putting the luan up first, but I think that would make it harder for me to get a consistent, bubble-free bond between the glass and the luan.
I didn't know what adhesive to use, and the one I bought, is what the RV parts retailer carried, and recommended.
The MSDS sheet names the glue Polychloroprene Solvent Adhesive. So far, on my test piece, it seems to work good.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
