Almot
Jul 31, 2014Explorer III
Techwriter: I hope some my cables will be thinner. A breaker with gauge 10 panel-controller wire, a breaker with gauge 6 controller-battery wire, a breaker with gauge 8 loads wire. No breaker #4 (yet). This for Pos bus. Neg bus will have wires in/out, but needs no breaker. Will see. In the worst case, will not install Neg bus in box.
Westend - let's see if I understand. Yes, screws heads from the back (if I do it this way) could prevent the box from resting flat on the wall. There is Ground lug on the photo - it is attached from the back, and its head does push the box off the wall. The box has 4 recessed holes for mounting screws - see the photo in the 1st post. So there are 4 bulges on the back, so the box is resting on those bulges, with a little clearance from the wall. Still, darn head screw of the Ground lug pushes the box off the wall. Will have to file the head off a little.
No, box is not mounted yet.
Mex: Yes, I thought of gluing. Yes, there are tiny stubs-pegs on the back of those insulators, and there are pre-drilled holes in the box for those pegs:
See drawing at the bottom
Why drilling the insulator? - look at the diagram in the link, the "sole" of insulator is mostly hollow already. Ebonite dielectric plastic, smells like it.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
