suprz
Jun 21, 2019Explorer
Attaching solar to roof
"IF" you were going to put Solar panels on your RV's roof and you absolutely could NOT drill holes in your roof (TPO, EPDM etc) how would you attach the panels?
TurnThePage wrote:
Double sided tape can be awesome strong. But you have to know that whatever you are taping to is going to be durable and reliable. When I prepped my EPDM roof for Eternabond tape around the edges, I caused the roof material to lift from the wood substrate in several places. If I had a solar panel taped on, it would have been a road hazard in short order.
I also don't know why the limitations for drilling or screwing. My EPDM roof is over 15 years old with two panels attached through the rubber to the roof trusses for 14 years. No leaks or other issues in that time.
