Old-Biscuit
May 30, 2014Explorer III
DC fuse in dist. panel blows when you turn water heater on using propane....and evidence of hot spot on high tension wire to spark electrode.
Unplug wire from circuit board and try new fuse.
If it doesn't blow..then get new spark electrode wire assembly.
IF it still blows fuse....new circuit board AND new spark electrode wire assembly
Dinosaur Electronics replacement boards are better quality then OEM
AS a new memeber please fill out 'signature line' so your rv info posts AND provide Model of items you are looking for info on.
Lots of different Brands/Models so different resolutions
Norcold/Dometic/Suburban/Atwood numerous models of fridges/water heaters/furnaces etc. It helps vs 'guessing'
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
