hogbobExplorerNov 20, 2015attwood water heaterHello I have an attwood water heater that won't work on gas or 110 volts. I checked the 2 amp fuse and the breaker. When you hit the gas side it dose nothing at all. Thanks for any help. KennyShow More
Chris_BryantExplorer IINov 20, 2015I would test for 12 volts through the front mount thermostat and flame fuse-
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Attwood Water Heaters
