Hello I have an attwood water heater that won't work on gas or 110 volts. I checked the 2 amp fuse and the breaker. When you hit the gas side it dose nothing at all. Thanks for any help. Kenny
What is the exact model number of your water heater? It should be shown on the exterior access frame. Some models use 12 volt control for 120 volt operation as well as the LP function. Make sure you have 12 volts to the switches.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
