hogbobExplorerNov 20, 2015attwood water heaterHello I have an attwood water heater that won't work on gas or 110 volts. I checked the 2 amp fuse and the breaker. When you hit the gas side it dose nothing at all. Thanks for any help. KennyShow More
enblethenNomadNov 20, 2015Detail 12 shows wiring for combined LP-DSI and 120 volt water heater. 12 volts goes to the switch before water heater.Atwood manual
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Attwood Water Heaters
