dougrainer
Nov 10, 2013Nomad
dano73 wrote:
Ok so if the relay is shot, what is the remedy? replacing the control board? And how would I go about testing that relay? And if that keeps the electric element on all the time, what prevents the propane from shutting off at the right temp?
IF there is 12 volts on the YELLOW wire coming out of the control board, THAT will keep the 120 relay engaged. If there is NO 12 volts on the yellow wire and the 120 element stays ON, the relay is bad---VERY RARE, I have NEVER seen one fail or stick closed.
The ONLY thing that will keep the LP ON is those 2 tstat's the ECO and the temp tstat. Either you miswired them or you have NOT replaced them correctly. The ECO(180 degrees), if you pull the wire off of it (either wire) it will kill power to the gas valve. If you pull either wire (brown) off of the main tstat(140 degrees), it will kill power to the control board. IF either tstat opens as it should, the control board CANNOT continue firing on LP,PERIOD. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
