eldondo
May 11, 2013Explorer
I found the fuse in the fuse panel. It looks good, but, my soninlaw told me how to check it with a voltmeter to see if it was intact by switching voltmeter to ohms. So, if the fuse is good, I am going to try to determine if there is juice on each side of the fuse. I am not sure how to do that. My soninlaw got called away before I could get a good answer from him. If that checks out I think I should try to clean all the contacts on that board type deal. I am thinking that the problem is it is not getting 12volts cause there is nothing happening when the switch is turned on in the RV. Any comments welcome.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
