Artum_Snowbird
Feb 10, 2015Explorer
Well this one is like new, essentially. If anyone has any insight as to how the igniter/sensor actually changes it's function from a sparking device to a thermocouple, and might have any input on how long the burner should run to give the sensor time to sense before shutting down, that would seem to be the problem.
Everything checks out with propane, furnace, stove, oven all working well. The burner fires almost immediately once the switch is on. The first pass is about 6 seconds, then subsequent tries are very much shorter, maybe only 1.5 seconds before it trips and puts on the red light.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
