enblethen
Oct 27, 2020Nomad
Most likely it is not a board issue.
High temperature limit switch, thermostat, sail switch, and low battery for a few items.
Start by isolating problem without throwing money at it.
Remove cover from thermostat. connect wires together. Furnace fan should start, furnace should start producing heat after short period of time. Separate the wires furnace should go into shut down mode, then turn itself off.
Test the high temperature limit switch for continuity.
What are the symptoms of it not working?
Do you hear ignitor sparking?
Does the fan run?
Does the fan run?
