enblethen
Oct 27, 2020Nomad
Locate the red wire entering furnace. Trace it along it's route; It should connect to white wire to the thermostat and to the circuit breaker/ switch. Leaving the circuit breaker it goes to the power point on the circuit board. BLO on circuit board should have power to the fan. Do you have a BLO terminal on the circuit board?
There is Three different wiring diagrams shown.
Step back to earlier step one: verify that you have good 12 volts DC to fan. Both power and ground. Make sure grounds are all tight on ground buss.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
