trailrider
Jul 30, 2023Explorer
If you have the newer version with the fan relay on the circuit board you need to check for power from the fan terminal to the fan motor when the thermostat is calling for heat. And make sure the thermostat is closing the circuit between the two white wires on this diagram.
http://techsupport.pdxrvwholesale.com/wp-content/uploads/2017/08/Atwood-7920-II-Installation-Manual.pdf
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
