JBarca
Feb 25, 2023Nomad II
Boundless2281 wrote:
Okay thank you. That's what I was afraid of. I did that and nothing happened. Verified 13+ volts to the positive and negative lead. No noise or anything from the furnace. I am going to check all the connections, but it seems like I may be buying a dinosaur board to replace mine.
Atwood had several control vintages of this furnace, the prior version used a thermal timing relay to run the fan and fan delay. The PC board, in this case only ran the gas valve, ignition, and flame sense circuit.
The next generation of controls did away with the timing relay and added the fan control to the PC board, which then controlled that fan and the gas valve, ignition, and flame sense.
Does your furnace have the thermal timing relay?
See the timing relay here; it is on the right end of the blower housing.
Here is the newer vintage with the fan control on the PC board—no thermal timing relay. A PC wire plug is on the front of the PC board; a blue wire, the T stat run signal, was added and is part of the fan control. The T stat run signal on the older thermal timing relay received the T stat signal.
This PC board has fan control on it. The black relay on the PC board in this pic is for the fan motor (the red wire is the fan motor hot wire, and the blue next to it is incoming 12-volt power for the fan motor). The round coil igniter also has a red wire but different insulation and goes to the electrode.
Some checks, and this assumes you have a 12.5 DC power or higher coming to the furnace.
If yours has the timing relay, they have been known to go bad over time. If you connect the two blue wires within a short period, the blower should run; if the blower will not run, either the motor is bad (less likely) or the thermal timing relay is bad (more likely). Check the fan power wires and see if it is getting power; if there is no power, then the relay is bad.
If you have no timing relay and twist the two blue wires, the fan should run after a few seconds as the PC board controls the fan motor. Check the fan motor power wire coming out of the PC board to see if the board is sending incoming DC voltage to the motor. If the board is sending power, then the motor has issues. If the board is not sending voltage, the board has issues.
Hope this helps
John
